what amp?
  • 3
aceorama1
18
chicago
I am going to be running two dual 4ohm alpine type-r subs wired down to 1 ohm and i need suggestions on a good amp. I have looked at the sundown 1200d and some other amps but they are a little more than i would like to spend. I want something that is going to put the least amount of stress on my electrical system though. So any suggestions would be appreciated.
188
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
388
6
486
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
773
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
562
aceorama1
aceorama1
chicago
99grandprixGT
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
