What are the problems with bandpass?
I'll give you the best answer that I can. Bandpass boxes can sound quite good if they are tuned properly to the speaker. Most genericly built bandpass boxes will work, just not as well. A bandpass box sounds 'boomier' and the bass notes aren't as defined. Also, a bandpass box generally won't hit as low as a sealed box. As for distortion, it may be drowned out a bit more, but just watch how hard you push your amp to avoid distortion.
The main problem I have with them is they tend to be one note wonders. This is due to the way they are tuned. Output at the tuning frequency is amazing. An octave or two Above or below the tuning frequency the output is almost non-existant.
Generally people who buy low quality speakers buy bandpass boxes but I'm not stating that bandpass boxes are bad the are usually used to drown out the distortion or to bring out the boom in your subs though your clarity usually lacks and it's not as defined as a sealed box . Sealed boxes are used to bring out the clarity and also a lot of the boom but if u got good speakers you can use both. There might be on the specifications on your subs how it works in each kind of box and the length and width of what it sounds the best in. So try looking for that.
A well designed ported enclosure can be a very good median between sealed and bandpass. They have greater output than sealed, and offer "tighter" bass than bandpass. If your into sound quality sealed or aperiodic is the way to go. If your into spl or just who can be loudest bumpin down the street I would go with a ported enclosure
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
765
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
816
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
CheapPyramidStuff
CheapPyramidStuff
Kamloops BC Canada
ramos
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
