What causes a head unit to get hot?
DetroitSteel88
26
Phoenix
long story short...
I had my local shop test my Clarion dxz855mp over the weekend, and they said it got hot after awhile.
Since that head unit has an AMP cancellation option (and I will be using external amp for door speakers and subwoofer), I am wondering if this may solve the problem.
I have just spent so much money recently, that I would like to use my old clarion unit since it was (and still is) a very nice unit.
Does the internal amp create all the heat?
Thanks,
Brian Nelson
is the heat causing a problem?
Not that I know of... I haven't use this head unit in many years it has been sitting around.
They had it hooked up in the shop, called me and said "it works, but is getting hot"
They were using the internal amp to make sure it put out music...
anything I should worry about? I figured that maybe it won't get AS hot if I use the amp cancellation option on the head unit.
I don't want it to cause any trouble. They seemed a little concerned by how "hot" it got, but I won't be using the internal amp, so I am hoping I will be safe.
As long as it sounds ok and doesn't clip in or out I wouldn't worry as it could just be the way it is. If it gives you 2nd degree burns after touching it than thats a different issue.
I would think that if the internal amp was shut off that it would indeed run cooler.
Well.... It depends on how hot it's getting. Is it getting hotter than a normal one does during use? Think of where a headunit sits. They sit in your dash, with very little airflow, around a lot of wires. All of them get to some degree of hot, but if it's getting extremely hot, that can cause a problem. I'd suggest trying it out outside of your car (bench testing or something along those lines), and seeing just how hot it gets. If it's not too bad after a couple hours' use, you should be fine. Shops sometimes tend to overreact.
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
6
490
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
760
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
802
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
DetroitSteel88
DetroitSteel88
Phoenix
Falcons
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
