What causes a sub to bottom out?
3.25 cuft33hz
hifonics 1208 @ 2 ohms for 900w
ia li 15"
ssf=29-30 hz
If your tuning is truely 33hz and your SSF is @ 30 hz it shouldnt be too bad. Maybe try setting it a little higher.
3.25cu ft shouldnt be too much for the 15".
How much port area?
How much port area?
no 3.25 is a little small for it but its all i could fit..
not sure about port area sorry
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
514
548
Jakeeck
Jakeeck
Eutopia
grimreper912003
