what do i need for a salt 8k
  • 5
sounds_explicit
currently im building a system in a tahoe 3 xv3 15s on a salt 8k at 1.33 ohms
rockford 600.4
possibly a 0-5k for mids tuned down ofc...
i have a brand x 390 alt voltage regulator at 14.8
plat agm under hood
northstar in rear
grabbing a brand x 6k bat
im sure that may be enough for that but i need more runs of power and ground.
i have 2 runs from front bat to rear bat.
big 3 done
1 rear ground
how many more runs from front to rear bat pos should i do
and how many runs of ground from front to back.
i plan on running about 2-3 ground from rear bank to frame underneath truck via a gromet in 3rd row.
I'll say add another pos battery run to make it 3 front to rear.
As for grounds I add 2 more than the total number of amplifier grounds to the rear battery because discharging is important
well here lemme say this. the 2 runs of pos from front to rear are 1/0 welding wire. from the rear bat everything else is 2/0 welding wire. so with that being said. i also have no dedicated ground from front to rear. is that a must? or can i ground the 2 batts in rear to frame with a few short runs.
so should i still run just 1 more run or try for 2. i can do the 3rd run in 2/0.
also i plan on runnning 6 pos 6 ground from the amp instead of 3/3.
main question is i guess. should i run 1 dedicated ground?
along with 1 more run of pos? or just 1 more good run of pos and make sure the rear batts are grounded to frame?
also the amp calls for 800 amps of fusing atm my 2/0 runs from fuses to amp is fused with 2 runs at 350 amps.
what would you suggest i run fuse wise to the salt8 amp? if i ran 3 runs should i do 300 amp fuses each run? 6 runs same thing?
Not sure if you're in a rush but you can also email brand x. Let them know your goals and your setup. They'll tell you what's enough. I did the same with underground power
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
260
671
437
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
489
sounds_explicit
sounds_explicit
cleveland ohio
audiobaun
