What do you think of my first enclosure? (Ported)
  • 6
Enemy5802
I have this enclosure tuned at 32hz, it's for a 12" subwoofer. Will be building this out of 3/4" mdf. Have no idea if i should use screws (predrill first) or wood glue. This is my first time making an enclosure and owning a car subwoofer. Port width is 2". Box has 16" height, 24" width, and i believe 12" length (end of subwoofer box)
I do not know which mono amplifier i should use but I will get to that once I am done building it.
Both
I like that you use inventor. It is my primary modeling software as well. It looks like a good design. I can't attest to the tuning or specs but the design work is fine. I think a 2" port should be fine but you might consider making it a tad wider, then longer to compensate. A lot of users here might tell you to throw make each port corner 45 degrees as well.
Would 2.25" be sufficient? Will probably make it a little more wider too. & yes I have heard that doing so will improve air flow but I will definitely do that to every corner (as well as the port corners).
Would probably be a 'little' bit louder (and easier construction wise) to just run your port interior across the back rather than folding... Is the box not wide enough to accommodate the tuning you wanted?
Are you suggesting that I make it L-Ported? If this does make it a little bit louder I most probably will do this.
What he said, easier construction, less bends. I don't think you will see much difference output wise, but IMO better of the two options, just double check your distance for the depth of the woofer.
The difference in output is probably less than a half decibel - (not really going to hear the difference), but the simplicity alone would be a reason to do an 'L' instead.
Unless your trying to fit a massively long port in there - not really any reason to fold it.
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
  • Locked
$200 plus shipping for the resilient taken out of the box, shipped in original packaging. (buyer pays venmo fees)
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
798
Enemy5802
Enemy5802
United States
garretttt4
