What do you think?
well, they are single 4 ohm so you need an amp that does 300 rms at 2 ohms
Honestly, it is that simple. Any amplifier will work well with the correct power and correct hook up. I do recommend adding that the THD levels may be around 0.5% as well for a better choice than just shooting for wattage. Also, make sure if your shooting for very low frequencies, that it may need not have a subsonic filter, but one is always recommended. Also, check that the fuses rate for good amperes, 50A would be good for 300W amp, or (2) 25A....without getting too involved.
Reddish Neck
TD's & Beer
Reddish Neck
Racine, WI
Moble Enclosurs
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
