What Happened to this amp?
  • 4
MPI
So I recently purchased a Rockford Fosgate P400-2 amp off of ebay... after installing it I turned my vehicle on and the blue amp Power indicator came on as it is supposed to, then my speakers made a few strange noises, the blue light dimmed and then smoke started pouring from the amp... (this all happened in approximately 5 seconds) and had all the gain and volume levels set as low as possible. This seller has good ratings and it was listed as being new (wasn't in the shrink wrap, but was still very clean and no signs of use) I opened it up so see what had happened in there and 4 of the MOSFETs had fried... does anyone have any ideas as to what happened? I was running it with another P400-2 and a P500-1BD (both turned on just fine) they were all wired in the same exact way.
Any ideas would be great...
The mosfets that got fried are marked with lightning //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
[/img]
Well Its a good there going to refund my money //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If everything was wired exactly the same way between the amps you listed - it would have to be a dud. RF and most other manufactures bench test their amps prior to packaging, so I'm surprised you would have a failure from a "new" amp. I'm guessing either the amp was tampered with, shipping damage, or some other installation error. The chances of a new amp frying like this is extremely slim, but I suppose it does happen.
184
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
386
6
483
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
771
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
560
MPI
MPI
Milwaukee
MPI
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
