What kind of amp should i get to get the best bass out of 2 15''Kicker SoloBaricL7s
Well since you didn't state a budget, I would get the US Amps 2000X. It's rated at 2000 watts mono, but probably more like 25-2600 depending on your electrical system. Heres the link http://usamps.com/default.asp?View=products/inv/usa-2000.htm Or if you had the money, you could get a Zapco 9.0, and that puts out 24-2500 watts as well. Here - http://zapco.com/nosound/index3.html These amps would be some of the best you could buy for those subs, because it would give you a clean 11-1300 watts rms to each. But if you are limited by budget, then I can think of some other options, but they won't be as nice as those two
USAmps are great, but if memory serves me correctly, the 2000 isnt a class D and so will draw LOTS from your electrics compared to the more efficient class D amp. For $1000 you could easily get 2 jbl 1200.1s, or an MTX8100D and have around $500 left over too!!!!
Originally posted by jtmoney USAmps are great, but if memory serves me correctly, the 2000 isnt a class D and so will draw LOTS from your electrics compared to the more efficient class D amp. For $1000 you could easily get 2 jbl 1200.1s, or an MTX8100D and have around $500 left over too!!!!
Yep you're right about that. The US's do take a lot of current. But if you can supply it, they are among the best, if not the best when it comes to power. You could grab a bd 1500 for less than a grand, and it would be nice too. I also like the 2 1200.1 idea.
Fuk that Get a pheonix Gold 500.2 Tantrum this will knock the sht out of them
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by LBX2G Fuk that Get a pheonix Gold 500.2 Tantrum this will knock the sht out of them
out of 2 15" L7s - r u on crack????//content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
eh, get 4 1200.1's, lol.
you can find em for around 260 each...
so just slightly over your budget and it will pound the **** out of those subs..
power is a subs best friend...
with quality subs liek those, ge ahead and throw it at em...
Originally posted by UK Bass Get a Ample Audio Exonic 1500DX
It is Class X and 3000w @ 1ohm
im afraid im having a bad day, so u're gonna get it //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
yeh!!! what a f*****g great idea //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif why doesnt he get a PYLE amp, or a BOSS WAR series amp..............or some flea market crap, like a 2,000watt amplifier for $9.99.
Ample Audio, for me and I presume other knowledgeable car audio forum members, is like Jensen, Boss, Pyle, Pyramid, Legacy - its cheap crap which you should avoid like you should avoid a bullett in your head.............
yeh its class X, so what......its 3000watt PEAK..............repeat after me..............P.........E..........A..................K.......................not RMS......RMS you will be lucky to get half of that, around 1500RMS...................but it probably wont even do that...........it may do say 1000RMS on a good day - and how much of that will be distortion, have a think about that.
whatever you're smoking, it must be **** good //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh:
another point - why get a quality driver like the L7, and buy a $ita$$ amp????
there are lots of good D class amps out there, DEI, Viper, Memphis (ST1000D and Mojo) - these are just some of the few that will produce REAL power, real RMS and that is why they cost how much they do................
get dual 2 ohm l7's and a memphis mojo wired in parallel series to make 2 ohm mono and hang on //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by audiolife get dual 2 ohm l7's and a memphis mojo wired in parallel series to make 2 ohm mono and hang on //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ohhhhhhhhhhhhhhh yeeeeeeeeehhhhhhhh.............the definition of killer-hertz!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif that WIKLL be painful!
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
11
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
294
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
303
$ Truplaya $
$ Truplaya $
Ohio
Alpineinstaller
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
