So I built my box a little bit ago and i finally got around to painting, i got a custom paint job on it done by me and my cousin that turned out really good.Now i want to protect that paint job with a nice clear coat. Were this becomes kinda weird is that i need the box to removable and for me to be able to put it in the bed on my truck without me having to worry about it. So it has to be a protective or somewhat protective clear coat as well.
Not only that, but figured we all faced this issue, but it needs to withstand a lot of heat. I bought MiniWax's Polycrylic Protective Clear and i was thinking it was perfect until i read it was interior use only and i called the tech support and they said it can only withstand up to 120F and in my car in GA in the summer, the interior just bakes like an oven.
I was recommended car clear coat as well, while this seemed to meet all of my criteria, i heard some mixed things about using it on wood. Things like it should only be used on metal because metal cannot expand and contract like wood can, causing the clear to crack. I heard it was perfectly fine to use on wood and no effects at all. I heard i need to use wood sealer before i painted the box to overcome the expanding and contracting problem. I have car clear coat and everything i need to mix it with as well so this is a viable option but wanted some more opinions before i used it.
So what do you guys use or what can you recommended me?
