That's exactly it - I should have just said it that clearly to start with //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Here's the thing. Most people who do it open their doors, apply vibration damper and add foam at the same time. They put it back together and it sounds better so they assume that both the vibration damper and foam contributed to the improvement. I've yet to hear anybody say they applied vibration damper, put it back together, listened for a while, pulled the door apart again, applied foam, reassembled and listened and could hear a difference.
Foam in the doors is one of the old wives tales of car audio. Most people advocating adding foam recommend 1/8" or 1/4". 1/8" can only absorb 27 kHz and above, 1/4", 13.5 kHz and above - not where the problems are. To add insult to injury, you really need to use closed cell foam inside a door. Closed cell foam is a TERRIBLE absorber, for the same reasons it won't hold water.
