what should be my box volume
  • 3
Jmdg
I have a Precision power PC18DS and I'm not sure what the volume of my box should be and how low i can tune it. i'm thinking around 26-28hz and maybe the box vol 5.5Cuft?
i have a long list of parameters but dont know how to use them. if someone can come up with the box vol and freq. tuning i can learn from there.
I have a Precision power PC18DS and I'm not sure what the volume of my box should be and how low i can tune it. i'm thinking around 26-28hz and maybe the box vol 5.5Cuft? i have a long list of parameters but dont know how to use them. if someone can come up with the box vol and freq. tuning i can learn from there.
I don't have any experience using that sub but from what I've found is if you're going to tune low you should make your box bigger as well. When you make your box too small it tends to make it louder at certain frequencies and very quiet at others. A large box tends to smooth out the response curve a bit which is very helpful for tuning low since it prevents your box from being too peaky on the low end and then dropping off at like 45-50hz
Go to youtube and look up " how to use winisd" theres a 15 to 20 minute tutorial with a download link in the description. Its a free software that uses all the parameters to see how the sub performs in different enclosures.
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
3K
The CT's are nice, That Sundown is a a frik'n beast!
7
764
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
655
Jmdg
Jmdg
Kentucky
Jeffdachef
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
