WHat size box for this sub?
SQ makes good amps. You largely get what you pay for with amps, in my experience. Some are overpriced, but the good ones are expensive still and the crappy ones are cheap.
---------- Post added at 06:10 PM ---------- Previous post was at 06:10 PM ----------
Those are fairly priced IMO
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Cclodbuster2017
Cclodbuster2017
Colorado
Clifff150
Decebal
    Jun 10, 2024
