what size box?
  • 3
e22s
i have an orion 1200d and (1) 12" dual 4 ohm Alpine Type R just sitting in my room (i totaled my car about 4 months ago and gave the other 12" to my bro)...any suggestions on how i should make the box? tunning and size......i listen to rap with heavy bass ALOT also if that helps...and its going in a 2005 honda accord sedan ex....thanks
thanks...is there anything in the moe lester box plans that should do me good? i just need the plans and im going to be building it my self...
up^^..peferably somthing from moe lesters box plans...is it possible to get it as loud or even louder if i were to have 2 12" hooked up to the amp? thanks
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
e22s
e22s
Antioch, ca
e22s
