What size terminals for KNU CCA 1/0?
  • 4
jjminch
Hey guys quick question. I have some of the Knu Concepts CCA 1/0 wire. Will be using that for my main run and then OFC 4ga to the amps.
I know the wire is oversized so would like to order some terminals that fit right the first time. I have a hammer crimper, so where is a good place to get them and what size? Thanks
[quote name='jjminch']Hey guys quick question. I have some of the Knu Concepts CCA 1/0 wire. Will be using that for my main run and then OFC 4ga to the amps.
I know the wire is oversized so would like to order some terminals that fit right the first time. I have a hammer crimper, so where is a good place to get them and what size? Thanks[/QUOTE]
I have the same Knu wire, and I fit it quite well into 2/0 lugs. it took a little work, but those I found were the best size for the wire. I'm sure you could get away with using 1/0 lugs, but it'd be much harder to fit the wire in. I used copper lugs I bought at Napa, which are about $2.50-3.50 a lug. Pricey, but worth it. Or talk to @mylows10 ; I think he sells terminals and lugs.
I have them. 100% copper with heat shrinks
I get mine from delcity.com Have you considered about soldiering them for a better connection?
I ended up going with a set from Sky High. Good price and included some heatshrink. I solder all the small wires, but don't have the setup to do wires of this size. I do have a nice hydraulic crimper and I'm my opinion the connections are better than anything I could solder.
I like the Sky crimps because at least from the pic they look heavy duty, something like a commercial application.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
4K
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
11
jjminch
jjminch
United States
jjminch
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
