what to do to my car?
  • 4
bigbirdy
hey guys its my first post here and thanks in advance for answering my questions;
i have a 1999 mercedes benz e320 that currently has 2 12" rockford fosgates running at 250 rms each.
i want to upgrade as these are not nearly as loud as i want them to be.
i want to put in 2 15" subs but im not sure what kinds to put in, and where to put them.
whats the loudest, most reliable 15" subs i can buy for under 200$
it can either replace the back seats, or ideally stay in the trunk. what will give it more oomph
thanks for helping out guys
Really depends on your trunk. 12s in the right box will do better than 15s in the wrong box. Go ported if you want loud bass. Go sealed if you want smaller boxes and tighter more sq oriented bass suggestions in the $200 range per sub new include sa subs, xfl subs ,obsidians dc lvl 2 ascendant arsenals tantric md or ld pick your poison
how much do you really want to spend... if your going over 1.5k rms your gonna need electrical upgrades including big 3 and AGM batteries. If your going over 2500 rms your gonna need better mids and highs to keep up with your system and also a high output alternator and extra batteries...
All advice aside, to answer your original question SoundQubed HDS315
I'm guessing he's keeping the 500 wrms amp he's got, considering he didn't mention a change in that.
However, I would take the $400 you have available, and get ONE 15 and a cheap amp that'll put out some decent power. I'd say run a BRX1100.1 on a SA15 and call it a day. I'm sure it'll sound way better and be much louder than the P3s or whatever you've got now. But you'd also wanna spend another $60-70 and buy the materials to build a proper ported enclosure.
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
207
A Link would be very helpful. Id be interested in taking a look at some gear
215
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
654
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
bigbirdy
bigbirdy
los angles
bigbirdy
