what to look for in a active 4ch amp ?
ok thanks guys,
was thinking there was more to it.
whats the best way to go 3-way active ?
i dont have a 3-way h/u, do i need that in order to go 3-way ?
this is why i asked about active amps.
im trying to plan this out.
Easier to do it with head unit...(ex 80prs) or if you want to keep current head unit, (alpine 700/701) and have a four way if wanted/needed for future needs..
the new KX is fully active/bp capable. you don't need a head unit to run active. there are many different configurations to achieve this, just depends on some of the equipment and how you are planning to run your set up. example, I'm 3-way active with a media unit that only has 2 sets of pre-amps. I have one set going to a 4 channel amp that is going to run my tweeter on channels 1&2 than my mids on channels 3&4. than the other set is going to be for my sub amp.
that kind of like my set up. except i have 3 rca outputs. 1 going to sub amp,, front going to 4ch ( same setup as your ) and rear going to a 2ch amp running a set of rf 6x9. for nor anyway. going to replace them with some pro 6.5 and super tweeters.
i ask about this is im going 3 way for front stage. and trying to figure this all out.
I run 2 of the Incriminator Audio 3.4s on a 3way active setup with rear fill.
to run 3 way active, youll need 3 2 channels, 2 4 channels or 1 6 channel.
Some Important things to look for is the db slope of the crossover, 12, 18 or 24db. Of course at least 2 of the channels need to have the ability to be bandpassed. I like to also find an amp that has flexibility of a frequency multiplier which really helps fine tune your crossover points.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
855
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
Without the wiring diagram I cannot be certain of the color associated with the head unit remote on or even if there is one on the HU. I assume...
47
5K
big scott
blazin low, and loud
big scott
edgewood, md
JFOODSTAMP
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
