What Turns U On (Head)?
Hola doods,
I was getting alternator whine, so I decided to see if swapping my Kenwood HU for a Clarion HU would help at all. Now after I had plugged it in and turned it on, the display came on fine, but as I was reaching for a CD to test it with, the HU just turned off by itself.
I noticed that it would still accept the CD and eject it, but refused to turn on and play it. I then took the Clarion HU out and put the Kenwood HU one back in, same thing: accepts the CD and ejects it, but refused to turn on and play it. Then about an hour later it refused to even do that.
The on-board 10A fuses for both these HU's are fine, obviously the HU's aren't the problem, and I wonder if the key to figuring out this problem is the fact that it would still accept and eject CDs even though nothing else was working.
Que pasa?
Is the hu grounded well? Try plugging in the ant and also wire your ground to Ur hsrness see if that helps also check Ur 12v and memory. Check both fuses in.Ur car.
i would pull out your meter and see if your getting proper voltage on the turn on trigger from the car. could of shorted something and popped a fuse in the main fuse panel.
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
6
155
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
554
Shojahan
Banned
Shojahan
San Juan Capistrano
mylows10
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
