What would be the best amp for my set up?
  • 3
MickyBFun
CarAudio.com Newbie
I have a 2003 Lexus ES300 with the stock stereo. I have 2, 10" Kicker Comp R subwoofers in a Kicker Comp R box. I have tried numerous amps and either am not getting enough sound from the speakers or the amp will cut out, I think because of too much power. What would be the best amp for my set up and how should it be hooked up? Please help.
I have always had issues getting good bass in a trunk setup without at least two 12" subs on 700+ watts RMS. I assume luxury cars are worse because of the better sound dampening. Most people ride with their seatbacks down to overcome this, so there is that.
Another thing may be the wiring method of the amp and signal. How is your's wired?
Sundown SIA1250. You can wire it to one or two ohms and get the same power. Don't wire it to ½ ohm.
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
10K
MickyBFun
CarAudio.com Newbie
MickyBFun
Temecula Ca
Bobbytwonames
Decebal
    Jun 10, 2024
