What's this box tuned to ?
  • 4
psylo535
tampa,fl.
Can someone help me out here, I have a box for 2-10"s and this is the specs :
outside dimensions are 44 x 14 x 14
Port is 3 x12.5 port length is first piece 9.5 x 12.5 and then it turns 11 x 12.5
The subs and bracing come out to .32 I thought it would be tuned around 32-33 but it sounds a little boomy like its tuned higher. Any help would be greatly appreciated
Yeah, it's 3/4" birch and I used torres also. 2 common port walls and single baffle for now. Got another baffle made but it wont add anything as it will be recessed subs. Wonder if I could add length to the port to tune it down. Really don't want to build again
Side slot port utilizes 3 common walls not 2. You could add to the rear port to tune lower but it will drop your net cubes. You could also invert the subs and it will drop tuning some.
Sent from my SCH-I605 using Tapatalk
You could try inverting the subs to reduce the displaced volume. You could length to the port inside to drop the tuning if you can spare some net volume. If you add it to the outside you can drop the tuning without any drawbacks other than it looking odd and needing more room to fit it.
The box is sub and port up. I text you last week ccstang for a design but your arm is still a mess. I gave it my best shot. I've tried 3 guys from this site to build and the other 2 just keep blowing me off
Well I added 7" to the port and the box sounds worse. Very boomy and just not right. Guess this box is a fail unless someone has a suggestion
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
624
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
712
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
836
psylo535
psylo535
tampa,fl.
psylo535
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
