When do i stop sanding???
  • 5
so you mean sanding between layers or final product?
i sand alittle bit between layers and then sand till its smooth and looks good for the final product
Sand as much as possible to get it "smooth" before laying down another layer. Yes your covering it up, but if you fix the base layers smooth then the others will be effortless in laying out smooth. You sand between cured layers to break the "wax" seal of resin so it will anchor in during your next "wet-out" and application of mat....
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
kgcolbyIII
kgcolbyIII
oceanside, ca
MxRacer476
