When?
  • Thread starter <BatteryBoy>
  • Start date
  • Replies 3
  • Views 1K
  • 1
<BatteryBoy>
Guest
When do you need to get a battery to power your system? I'm about to buy a new system and I want to know if I need to add in a battery and setup to the price list. So, how much crap can you run off your regular car battery til you need to separate them?
What do you plan on running ? An extra battery may hurt instead of helping. Adding an extra battery puts alot more strain on the alternator.
I'm going to have 12" Sub, 350Amp, and a newer head unit...I'm just curious as to how much more I'd have to add to justify getting a second battery...or second power source..
Alot more
Unless you plan on upgrading your alternator. Which means big time $$$. I wouldn't worry about. If you have trouble with your lights dimming. Add a cap or two. If you really want a battery. Start by replacing the battery under the hood first. In my daily driver I'm running two punch hx2's off a bd1000.1 and a power800.4 running my focal comps in the front and midbasses in the rear. All with the regular factory 120 alternator. The only thing I did was upgrade the battery under the hood. I also upgrade the factory wiring on the alternator. I changed this to 4 gauge instead of the factory 8 gauge.
Guest
ramos
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
