Which 15" sub will be the loudest?
BSchrowang
Budget Builder
I am trying to choose between 2 different 15"s.
The American Bass XFL 1544
1200rms
Dual 4 ohm
Or the Soundqubed HDS315-D4
1500rms
Dual 4 ohm
I would be running 2 of these in a trunk box ported around 32hz and about 6 or 7 cu ft.
Will be running off a Planet Audio BB4000.1 at 1 ohm (2500-2800rms)
I want to know which sub will produce a higer spl number but also retain a reasonable sq.
And please dont just say buy a kicker or recommend me a $500 sub or amp.
I would do the American Bass XR 15 (it's not much more than the XFL and has slightly better soft parts). Will meter slightly less but is more musical (its a good daily sub).
I took a look at the XR and it does look pretty good but i am more concerned that there are little to no reviews on it and i cant seem to find any specs on it other than rms. And im not overly worried about what it will meter but i definitely want the bass to hit you in the chest
I would stay away from AB and go straight to soundqubed if you want that punchy chest bass. American bass tend to give a smoother low end rumble and throaty, ear pressurizing, car windshield flexing bass in most boxes vs the typical 40-55hz chest punch sound signature you get from soundqubed in most boxes. Unless you gonna experiment, most generic custom ported boxes lead to those results. Dont tune low either 32hz is a mistake if you going with soundqubed. 8 cubes tuned to 35-36 would be good.
I know a good single 18 that would work perfectly in that space with that power //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well my original plan was to tube my box to 37hz but i was told that would ruin my low end response. And when i said the bass should hit me in the chest i didnt mean it litteraly. I meant that the bass should be heavy and hard. I do enjoy the deep lows that my current subs struggle to hit. I dont really need/want to hear anything over 70hz. I had already decided to go with the xfl but I figured I should see what everyone else thought before i dropped a grand into trunk.
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
6
83
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
298
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
472
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
583
BSchrowang
Budget Builder
BSchrowang
Peru Illinois
Massive spl
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
