which amp to use with ctx65cs
The Arc will out perform those discuss MB amps across the board. ARC and Zapco are known to be super clean and quality built amps.
211
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
413
6
494
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
788
herrrerrera
herrrerrera
pomona, ca
Maglite
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
