Which amp?
  • 4
I’m about to buy 2 dual 2 ohm skar evl subs and I’ve got three amps in mind ct sounds 1500w, Skar 1500w & D4 Sounds jp800w which dynos 1000w which should I buy? Thanks I appreciate the help
The CT is the only amp I would choose above 1k rms for the price point out of the 3
216
418
497
  • Locked
790
Jerk1981
Jerk1981
Trion ga
audiobaun
