Which amps should I get?
  • 2
Rell868
CarAudio.com Newbie
So i ordered the JBL gto393 6x9 speakers which is a set of 2 speakers and I also ordered Jbl gto609c component speakers set. Also ordered the MTX terminator series subwoofers which is 1200 watts dual sub enclosure. I'm getting a 2400 watt Monoblock amp for the subs. But I don't know what amp I should get for the JBL mids and highs. I do want the Max power I can get for the mids and highs though any ideas?
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
3K
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
160
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Rell868
CarAudio.com Newbie
Rell868
Jeffdachef
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
