which bypass module???
  • 6
555F should work well for ya. I don't think you need the S for that truck. As long as you are careful of the placement of the transmitter, you are fine.
I forgot that truck used securelock. You will most likely want to use the S. As I stated before, be sure of your placement on the transponder. They are quite tricky. Test and retest. It will save you heartache in the long run, I promise.
Thanks for all suggestions and all is installed and working great.
13
887
How exactly would I do this for after market amp and since factory is 14 channels how would I get close to the factory amp? I hit a curb on...
4
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
4
864
Your crossover slopes will be steeper ..so sharper cutoff points ..say deck is 24db and amp is 24db youll have a 48db slope the subs will still...
5
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
SATX210
Banned
SATX210
GO SPURS!!!
zfactor
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
