Which component to chose between those 2 for SQ/quality vocals?
  • 2
ianik777
CarAudio.com Regular
131
6
Mauritius
Pioneer D65c
Size17 cm
Maximum power270 W
Nominal input power90 W
Frequency response32 - 49.000
Sensitivity84 dB
Impedance4 Ω
Crossover Frequency3000 Hz
Mounting Depth65 mm. Tweeter: 15 mm
Cut-out Hole144 mm
Woofer materialAramid Fiber interlaced IMPP™ cone
Voice Coil typeCopper Round Wire 2-Layer
Voice Coil bobbin typeGlass Imide
Lowest resonance frequency62 Hz
JBL GTO 609c
Type:Two-Way
Nominal Impedance:3 ohms
Power Handling (RMS):5W – 200W
Power Handling (Peak):270W
Sensitivity=2.83V/1m) 92dB
Frequency Response:67Hz-21kHz
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
844
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
854
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
ianik777
ianik777
Mauritius
hispls
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
