Which Do I Connect My Amps Remote Wire To?
  • 5
I have two blue wires.... one comes from the headunit and the other comes from the adapter harness.
The one coming from red adapter harness is on the left (Bottom in my hand) and the one coming from the headunit is on the right (top). Both Remote Amp wires, I just don't know what to do. Do I solder it to HU remote wire and leave the harness wire taped and alone? Or do I connect it to the adapter harness blue wire and leave the headunit wire alone? Or do I connect it to both the HU remote wire and the Adapter Harness wire, making a three wire solder connection?
I have an alpine that has two wires like this. The manual says one goes to the head and the other is to pass on to additional amplifiers. You may look up the manual, because one is a remote in, the other is a remote out. If the device has an in and out harness separately, or one is connected near/with the battery + and -, that may be your in. You could put juice on them one at the time and see which is the remote in without messing it up.
If your car has factory amplifiers then you need to connect the head unit's remote wire to the aftermarket harness and then connect the amp you're adding to the aftermarket harness as well. That way, the factory amp(s) will turn on.
683
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
887
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
heimsothe
heimsothe
Portland, OR
bbeljefe
Decebal
    Jun 10, 2024
