Which of these speakers should I get?
  • 3
Why settle?
You can build a very nice sounding setup if you're willing to put in some work. Piece together some components and you'll be much happier.
At the very least, I'd try to get a component setup. The crossovers should be better (for the most part) than what you'll find built into the coax drivers.
Only reason I would use the kick location was if the speaker magnets did not clear the door's regulator/glass. As for the 3way location, I would...
9
Hello all, need some wiring advise for some speakers. I have four JBL 3ohm speakers and two 4ohm tweeters, I am running a amp the can run either...
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
117
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
341
alecd70
alecd70
Place
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
