Which one of these 3 speakers i should choose? Audison vs eton vs ground zero speakers 6.5"
  • 1
mio
EUROPE
Hi , i will upgrade my speakers so , please tell me your personal opinion so i dont make costly mistake.
here is my current set up,
p99rs,
mosconi pro 4/10 amp powers speakers ,
mosconi pico powers the utopia be tweeters,
audison apbx 10as sub,
focal utopia be tweeters,
arc rs 6.0 speakers,
morel virtus nano speakers- which will be replaced with pair of these 3 options,
1st option, audison thesis sax ii,
specs. of course if someone needs more specs of chart or something there is always a i-net specs option i am not sure if i am allow to post such long things here.
CompWoofer
Size165 mm (6.5″)
Power Handling150 W Continuous Power
300 W Peak Power
Impedance4 Ω
Frequency Response40 ÷ 4500 Hz
Sensitivity87 dB/Spl
MagnetN48 “H-grade” Neodymium
ConeTPX®
Audison is probably the most expensive option but price difference between audison and eton is very minimal.
2nd option eton german company .
model is Called
eton ONYX 16
specs :
Bass / midrange
165 mm (6,5")​
Impedance
4 Ohm​
Nominal / music power
90 / 140 W​
Sound pressure level
89 dB​
Outer diameter
165 mm​
Cut-out diameter
146 mm​
Installation depth
79,5 mm​
- 165 mm (6,5“) high-end bass/midrange driver - reinforced, ribbed paper cone - handcoated special silk dustcap - symmetrical tindle guiding with silk spider and special ventilated voicecoil former - High-End aluminum die-cast basket with airow optimized ventilation - Powerful neodymium magnet - Nominal / music power 90 / 140 W - Impedance 4 Ohm - Sound pressure level 89 dB - Outer diameter 165 mm - Cut-out diameter 146 mm - Installation depth 79,5 mm
Basket diameter (in mm)165
Installation diameter (in mm)147
Installation depth (in mm)80
Magnet diameter (in mm)68
Membrane materialpaper
Voice coilcopper
Voice coil formerglass fiber
magnetNeodymium ring
highest separation freq.3.5 kHz
lowest crossover freq.no
Weight:980 g
OthersWoofer
Nominal impedance (in ohms)4th
DC resistance Rdc (in ohms)3.25
Voice coil inductance Le (in mH)0.43
Voice coil diameter (in mm)32
Membrane area Sd (in cm²)139
Resonance frequency fs (in Hz)72
mechanical quality Qms5.69
electrical quality Qes5.69
Total Q factor Qts0.76
Equivalent volume Vas (in l)0.67
Moving mass Mms (in g)14.1
Rms (in kg / s)1.12
Cms (in mm / N)0.35
B * L (in Tm)5.25
Sound pressure 2V, 1m (in dB)87
more information is available into their web site with some charts and things i dont understand.
Last option
GROUND zero i think this model is available for some time into the market, unfortunately i cant hear any of these and i cant travel to hear them abroad as well so we need to choose them based into their materials and specs wise.
These components will be imported they arent available anywhere where i live in bg.
Specs of ground zero
GZUK 165SQ
are.
180 Watts max
6.5″ sound quality midwoofer with GZ aluminum cast basket and aluminum cone
  • 6.5″ sound quality midwoofer
  • 50 mm / 2″ copper voice coil
  • Black anodized aluminum cone
  • Linearized neodymium motor
  • GZ design aluminum cast basket
  • Universal 4 ohms version
  • Incl. GZ designprotection grill
  • Gold plated screw terminal
  • 1 pair / package
ModelSound quality midwoofer
Diameter165 mm / 6.50"
Power Handling (RMS/max.)120 / 180 Watts
Impedance4 Ohms
Efficiency87 dB
Frequency Response40 Hz – 3500 Hz
Voice Coil50 mm / 2" copper
Membran Layoutanodized aluminum
Magnet materialNeodymium
Mounting Ø144 mm / 5.67"
Mounting Depth63 mm / 2.48"
Resonance Frequency (Fs)54.6 Hz
Ground zero are the cheapest
they cost 2 times less compared to audison, and also their resale value is close to zero,
keep that in mind.
if you need more information let me know thanks.
Only reason I would use the kick location was if the speaker magnets did not clear the door's regulator/glass. As for the 3way location, I would...
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
297
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
224
mio
mio
EUROPE
mio
Decebal
    Jun 10, 2024
