which one will make my speakers sound better
  • 3
Heavy hittin
Maryland
trying to get the best sq out of my speakers...what is a better way for me to do this with my x overs...should i set my x overs on my headunit to off and cross them over at the amp...or cross everything at the headunit and instead of putting my 4 channel amp to hpf put it to off...
oh ok...im using an alpine pdxf6 as my 4 channel and a kenwood excelon dnx690hd double din as my headunit...if that helps at all...but ill give it a try
Hertz makes good speaks as does Focal. Often times how "open" a system will sound depends on the vehicle's interior. Big wide dash boards tend...
11
901
I would pull each speaker and test as well . Check with a DMM and a different HU or? as stated. A 12v battery and an Old HU usually works just fine
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Heavy hittin
Heavy hittin
Maryland
mylows10
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
