Which sub should I use?
I have several decent subs that I can install. My question is which will be the loudest given the proper enclosure with an aq2200 as the amp. 110 amp alt, big three, second 80ah battery.
1. Sub in the car now is a Fi bl 18. It's loud but seeing if anything I have will be louder.
2. 15" Fi btl n2
3. Dd3515
4. Re xxx 05 model
If you've seen my other post I'm going to a bass comp next sunday. I'm trying to bring the best set up possible.
---------- Post added at 09:42 AM ---------- Previous post was at 09:42 AM ----------
Also it's going in the escort Wagon
Subs aside for now, you have a 110a alternator and a 2200W amp. You won't be able to take full advantage of its power due to electrical restrictions of your system. That aside, from what I've read, the BTL would probably be the loudest if you can take advantage of full amplifier power.
I understand my power isn't up to par but I don't play it loud for a long period of time. I give the batteries a good amount of time to charge in between demos. I listen to it moderately when it's just me.
That's what I think but I know that btl n2 is pretty nasty. I just need to stop being lazy and try them in the car. I have a box that would probably work well with either 15s.
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
960
Have you check to see if the prefab would fit...
13
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
3K
Not sure on your level of knowledge here. You can wire your sub up 2 different ways, resulting in 2 different resistance (ohm) values. Your amp...
31
4K
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
284
swanginfleet
Houston, TX
AndrewHD
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
