Which subs would you bang?
jabagos
I currently have two old (swr-1041d) alpine type r 10" 300 watt rms on an audiopipe 1k watt amp. I recently got two one year old Rockford p3 12" subs which would you bang? The alpine or the Rockford.
Someone explain this to me, tighter gap = more SQ, as the air doesn't move as freely, controlling the woofer more, and a wider gap is more SPL because it allows more air to move at the expense of sloppier response???
I guess, I was just talking about physically banging a sub
Negatory.
Daily or SPL: Simply put, if you plan on listening to any type of music you MUST choose the daily option. If it is strictly for a competion/tone only scenario then choose the SPL option. The reason we have these options is the gap tolerances between the two are different. The gap in the SPL woofer is much tighter and FAR less forgiving in comparison to the Daily option. The Daily option simply gives the coil more wiggle room inside of the gap to deal with the non-linearity tendencies that you can get into when you are using a sub in a daily driving scenario. Typically SPL applications deal with 1 note and it does not change, therefore we can make the gap much tighter and get all of the motor strength that we can out of it.
Easiest explanation straight from Fi.
Oh and I would go with the P3's I guess. More cone area ftw.
I dont usually bang my subs. Ill tell you like I tell everyone else. My subs will beat, bump, thump, knock, slap, and slam, but they do not bang. Clearly the Rockfords will punch and you said you were looking for bang so I would try the Alpines, but Im pretty sure they just Hit.
Kodas like big sealed boxes and can't handle power. I shredded the surround on my 8 in .4ft³ and 350w My 10s on 1000w for the pair one coil...
9
275
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
440
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
511
jabagos
jabagos
Houston, TX
Liquid Bass
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
