which wires are speaker ground
  • 2
Ktm898
i bought a truck wired for a 4-channel but the speaker wires are not color coded. Is there anyway i can find which is ground and which is positive of each speaker. The wires for each speaker are connected to each other but i can't figure which is which.
Take a 9 volt battery and touch the speaker wire to the leads. If the speaker pops out, the + will be the wire on the + of the batt. If it pulls in, the + will be the opposite.
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
9
Try placing the subs in the front seat, to see if the issue persists. Just for diagnostic purposes. It may be wiring, but the distortion may be...
961
Ktm898
Ktm898
Louisiana
CSCStang
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
