Who still repairs Old School Amps ???
  • 5
Boominburban
100
Athens, TN
I need to find someone reputable that can repair the 1991 Kenwood KAC 1023 and 823 amps that I just bought. The 1023 is going to need parts,( 2ch rca input/output combo, and possibly the small pcb it solders to) the 823 is most likely a bad solder joint. And I just don't even want to mess with them. I am beyond disgusted at this point, and would just rather pay someone else to repair them.
Respond here, pm me ....either one will be equally effective ....
TIA .....
I need to find someone reputable that can repair my 1991 Kenwood KAC 1023 and 823 amps.The 1023 is going to need parts,( 2ch rca input/output combo, and possibly the small pcb it solders to) the 823 is most likely a bad solder joint. And I just don't even want to mess with them. I am beyond disgusted at this point, and would just rather pay someone else to repair them.
TIA .....
Just curious price on them given the broken state?
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
4
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
Boominburban
Boominburban
Athens, TN
Boominburban
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
