GreenBlunt 10+ year member
They're many car brands in the market, they usually come with factory head unit, but maybe only with radio or CD player, can't fulfill the needs of some people, that's why they would like to update it to better OEM car stereo, that's Car DVD player. But except some common DVD player, some brand cars need Special ones which can only fit their own, and usually they're much expensive than common ones. For example, Toyota, Skoda, VOLKSWAGEN, Mazda, and HYUNDAI. Why these Car DVD player deserve more value?
1. One-to-one made for each car model, they stand for unique and luxurious car DVD players which are distinctive from common ones.
2. Their appearance and electric circuit are seamlessly matched with the original setup in your car. Unlike common Car DVD players, you can install them easily without any modification.
So you know why they are more outstanding. But you can still hunt for better price through some good deal like this one. It will help to save your money, and since they are very easy to install, you don't need to ask for help of professional installer, you can totally DIY yourself.
Then how do you install by your self?
1. Open the hood of the car and disconnect the battery. You can disconnect the negative cable only and still be safe, but it's best to disconnect both the positive and the negative cable.
2. Using the proper screwdriver, take out the screws holding the factory stereo in your car's dashboard, then remove the stereo from the dash. You may have to remove parts of the dash to take the stereo out.
3. Carefully remove the connectors from the back of the stereo. Check the connectors to make sure they're not broken or dirty.
4. You can buy a wiring harness designed for your vehicle at a car audio and video equipment dealer; these are intended for aftermarket installations. Connect the wiring harness to the car's connector. See the wiring harness instructions for the proper connection.
5. Insert the in-dash DVD player in the aftermarket installation kit head unit. All dashboards are different, so you must buy an installation kit that matches the make of car.
6. Connect the other end of the wiring harness to the back of the DVD player. Connect the antenna cable to the antenna input on the back of the DVD player.
7. Insert the DVD player and the installation kit in the car's dash. Put in any screws that are required and replace any dash panels that you removed.
8. Replace the battery cables and make sure they are tightened. Close the hood and turn on the car. The in-dash DVD player panel will light up if the installation was successful.
