Will I be able to tell a difference between 18 watt rms and 45 watt rms?
  • 4
ethanm1
My dad's truck has a basic aftermarket head unit installed and I am in the process of replacing all 4 speakers (crappy aftermarket speakers installed by someone else) with JBL 60 watt rms 6" x 8"s (truck is an 03 f250 so the speaker sizes are weird). The two speakers I have already installed sound better already, but the head unit is only pushing 18 watts rms. I was thinking of adding an Alpine 180 watt power pack (Link below) to bump up the continuous wattage to 45 watts per speaker. Would there be a big difference in sound quality if I added the power pack? Thanks in advance.
Power pack:
Alpine Power Pack 180W Class D Bridgeable Multichannel Amplifier with HighPass Filter Black KTP-445U - Best Buy
Speakers:
JBL 6" x 8" 2Way Coaxial Car Speakers with Polypropylene Cones Pair Black GX862 - Best Buy
Power pack:
Speakers:
That amp is bridgable so Id bridge both channels (combining 4chs to 2chs) and run to the JBLs it will make a hugh difference ...I have two of the earlier versions of that amp and they are very nice ....I have a much better very high quality 6x8 in that price range if you want to PM me ...that is a night and day difference in the speaker your looking at ...
I am using that amp on a set of.rockville 6x8 comps, and I agree with louisianacrx, brigde it, it will give you 90wrms, and will make a world of difference. It kept up with my bc2k on a set of tc2000 12s.
You still can't expect much bass from a 6x8, but at 90 or even 45w they'll play significantly louder w/o distortion.
FWIW - 45w to 4 speakers vs 90w to 2 would net roughly the same loudness. I'd go the x4 option as I don't think overpowering a 6x8 by 50% is worth the stress on the speaker especially when going th 45x4 route will get you similar results.
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
360
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
9
ethanm1
ethanm1
Houston, TX
n2audio
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
