Will i be okay with my stock alt?
  • 4
I have a '06 impreza 2.5i. This model has a 90A alt. Right now i have a kicker dx600.5 but soon want to add a hifonics 1200D for a single sub. This will push around 700W at 2ohms. I plan on doing the big three before i put the new amp in. Will i be okay with the stock alternator with this build?
Maybe get a decent AGM upfront. I ran 1200 watts to my subs and 340ish watts to my front stage on a stock 100A alt for a while without much issue. Without my Big 3 though I had drastic drops.
Okay, how big do you suggest for a battery? And in theory since I'll have the fifth channel disconnected on the 600.5 it should only be pulling around 300.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
590
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
789
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
513
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
639
dagormz
dagormz
United States
marcos65
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
