Will my alternator handle my audio system?
  • 4
nik_72
PA
I have a 2010 ford focus and I will soon be adding a sub. I have read online that some car alternators can't handle large amp.
Now I haven't decided if this is the exact items I will go with but the specs around what I want.
Amp-
Alpine MRP-M500 Mono subwoofer amplifier — 500 watts RMS x 1 at 2 ohms at Crutchfield.com
Sub-
JL Audio 12W3v3-2 W3v3 Series 12" 2-ohm subwoofer at Crutchfield.com
Already in the car, I have installed 4 6x9 kicker speakers in the doors (can't remember the specs) and when I install the sub I will be adding a double din head unit.
Now to the main question, will my alternator be able to handle the sub/amp without effecting the electrical system? I searched on the internet and from what I can find, the stock alternator has an output of 120 amps. It that enough to handle everything in the car without damage to the battery or alternator?
I know people maybe suggest a cap but that only cover a big hit and not a constant draw, right?
You should be fine. A general rule of thumb is typically you don't want more than 2k on a stock alternator. Caps are useless, get a second battery if you need to. I believe someone is selling an XS Power D925 on here for a steal, it's small but will definitely help if you're having dimming issues.
I added interior after market led lighting and there's phone charge, that it lol
im not too familiar with what the output is going to be on the led lighting. phone charger is probably not very much. i think if you were to do the big 3 you should be fine. thats not a bad size alternator for stock. you can always buy a voltmeter and install that too and if your voltage is going low i.e 12v area when the bass is hitting than your going to need an agm or a h.o alternator but in my experience im thinking you will be just fine if you do the big 3 in 4 gauge ofc wire
---------- Post added at 10:25 AM ---------- Previous post was at 10:24 AM ----------
**** i wish i could have gotten 2k on a stock alternator. i could only get around 700 on mine. crappy 90a alt though.
It can be done if you do it right, and by that I mean a lot of big batteries. My stock alt is 140a, bigger than some peoples "high output" alts lol
yeah that is true. im in the midst of getting 4 xs power batteries and having a 2 h.o alternator setup so i get the lots of batteries.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
nik_72
nik_72
PA
CrossoverOre
Decebal
    Jun 10, 2024
