will running my head units internal amp to 2 ohm speakers destroy it?
  • 3
phatcat600
yeah my name is stupid
I installed my aftermarket HU in my Grand Price with Bose expecting to replace all of the speakers to match the right load but the cheap JBL GTO's I bought for the doors sounded horrible so I put the stock 2 ohm Bose garbage back in. Will running them off the HU at high volume long term ruin the internal amp? I'm not an electronics major by any means but my understanding is that the HU will be pushed a lot harder with this configuration.
Check the manual for your specific model, if there is a rating for 2ohms(meaning its 2ohm stable) then it will tell you and list the specs for that ohm load. Although i dont think alot of models are 2ohm capable
I bet after impedance rise you'd be right around 4 ohm. I know infinity configures most of their speakers at 2 ohms and say they are safe for HU power.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
681
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
phatcat600
phatcat600
Dowagiac, MI
adio25
Decebal
    Jun 10, 2024
