Will the buzzing hurt my speakers?
  • 4
Morphsuit
Ok I finally got all my new door speakers hooked up and I hear buzzing when the head unit is turned all the way up with no music and rcas in. You can't hear the buzzing at low levels or when you take rcas out. Got great ground, RCAs are ran away from power so my question is can I just go ahead and put everything back together and enjoy my speakers? Will that buzzing hurt my speakers at all or affect them? It doesn't cause any distortion at all.
Thanks!
Hi Morphsuit, here in the great (sogg) PacNW I've heard all of my life when vehicular electric components start going mushuga I've often heard "Your grounds are bad" not knowing what it meant. Belonging to a Jeep group and noting posts by an auto electrical guru he's posted the following;
"JEEP WAS THE CHEAPEST AMERICAN COMPANY I'VE EVER SEEN.
They simply didn't add dedicated 'Grounds' unless forced to and every circuit is 'Undersized', meaning you can't expand on it without out stripping the capacity of the circuit.
RULE #1 .
IF THE JUICE GETS IN, IT MUST GET OUT FOR ANYTHING TO WORK.
RULE #2 .
IF YOU WANT IT TO WORK, ADD A DEDICATED GROUND. (see 'RULE #1 .')
RULE #3 .
EVERY ELECTRON YOUR VEHICLE USES COMES FROM THE ALTERNATOR, NOT THE BATTERY!
RULE #4 .
CRIMP CONNECTORS AND 'SCOTCH LOCKS' ARE NOT PROPER ELECTRICAL CONNECTIONS!
RULE #5 .
YOUR JEEP IS ABOUT 7 ELECTRICAL CIRCUITS FLYING IN CLOSE FORMATION, BUT NOT ACTUALLY CONNECTED UNTIL YOU PUT IN DEDICATED GROUND WIRES.
RULE #6 .
WHERE RUST IS, ELECTRICAL CONNECTIONS WILL NOT BE.
(If you don't have any rust , this doesn't apply to you!)
RULE #7 .
STEEL IS A HORRIBLE CONDUCTOR OF ELECTRICITY.
RULE #8 .
JEEP WAS CHEAP! THEY ONLY INSTALLED MINIMAL CIRCUITS TO MAKE THINGS WORK. IF YOU 'ADD ON' ANYTHING, YOU WILL HAVE TO PROVIDE MORE ELECTRICAL CURRENT TO MAKE IT WORK CORRECTLY.
RULE #9 .
HEADLIGHTS ARE SACRED, ESPECIALLY LOW BEAMS, AND SHOULD BE TREATED AS SUCH TO KEEP YOU ALIVE!
RULE #1 0.
CIRCUIT PROTECTION (Breakers, Fuses, Fusible Links) KEEP YOUR VEHICLE FROM BURNING DOWN. USE THEM! "
While 'JeepHammer' focuses on Jeeps his remarks cross over to most other vehicles, especially given the wimpy wiring I've seen myself on late model autos. All that being said, did you ground the speakers back to the head unit wiring? Or to a body panel? If it's more of a popping noice an old school fix is to add a capacitor on the power feed line to head unit, but I'd suspect addressing your grounds first. On my Jeep, I pulled a ground bus bar from an electrical panel at Hab for Humianity ran a 6 gauge wire from my negative battery terminal of my secondary battery, and in turn ran all of my grounds to the bus bar. It's amazing how simple things like this have such a large impact.
Hi Morphsuit, here in the great (sogg) PacNW I've heard all of my life when vehicular electric components start going mushuga I've often heard "Your grounds are bad" not knowing what it meant. Belonging to a Jeep group and noting posts by an auto electrical guru he's posted the following;"JEEP WAS THE CHEAPEST AMERICAN COMPANY I'VE EVER SEEN.
RULE #1 .
RULE #2 .
RULE #3 .
RULE #4 .
RULE #5 .
RULE #6 .
RULE #7 .
RULE #8 .
RULE #9 .
RULE #1 0.
In regards to rule 4, If a crimp connector isn't a real connector then what is? He was referring to like those crimp on ring terminals?
Solder. After years of fooling around with those solder pens I finally found a new Weller solder gun on sale. I've used this thing for so many years now I've started investing in new tips.
Well... seeing as almost all head units distort at high volume it could very well be that. NEVER turn the head unit all the way up unless you enjoy fried speakers distortion kills speakers far to quickly and unless you have the Steve meade distortion detector you have no idea if it is causing distortion or not
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
NPR is pissed. If you followed NPR, they actually used to be somewhat balanced, certainly more balanced than mainstream news. They definitely...
Morphsuit
Morphsuit
Oklahoma City, OK
jc4def
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
