will this stuff work...help me plz
  • 1
sk8board4life86
gautier
i have 2 performance teknique 12 that put out 500 watts rms each and peak out at 1000 watts each
will a legacy la1020 4-channel 1000 watt series 2 amp work it can be bridged at 500w@2 channels but i dont think that is rms please help me
if i push them hard will i blow my amp or speakers
what power of kind of amp would u suggest if i need a better on
If you want good cheap power for subs, try the Lanzar 1200D @ $236. It puts out almost 900WRMS @ 2 ohms and over 1200W at 1 ohm.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
11
use the icon where it says insert image, icon. press that. How to get your pictures on your computer? Use your iPhone. Then transfer it to...
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
5
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
496
sk8board4life86
sk8board4life86
gautier
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
