Will This Work For My 8" Sub?
  • 3
ObTechAudio
Provo, UT
Hey Guys,
So I'm looking to finally put in a sub that I've had sitting around for a couple of months now. It's a SoundQubed HDS208 D2. It will be getting roughly 500 watts rms, which is a bit under what SoundQubed recommends, but it's what I got right now. I'm very limited on space, so my maximum dimensions are 20"L x 10"W x 14"H. That is basically 1.14 cubes before displacements. I want to tune it around 36hz, so I'm thinking of an aero port 3" diameter and 11" long. After displacements, I think I'll be in the .85-.90 cubes range. Is this box sounding like it will be a good fit for that SoundQubed, or do I need a slightly bigger box, different port, etc? I'm not familiar with the SoundQubed 8", so any suggestions are appreciated.
What type of port? Traditional slot or an aero?
---------- Post added at 05:53 PM ---------- Previous post was at 05:52 PM ----------
I have one in .75 @ 32 and it does pretty good off 300 watts
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
6
83
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
299
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
472
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
583
ObTechAudio
ObTechAudio
Provo, UT
garychoffmann
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
