will this work
  • 3
Ive never ran Kicker subs.. reconsider your wiring.. That amp is NOT 1 ohm stable. what are the subs Final ohm rating?
Edit: dual 2 ohm? or 4 ohm?
im getting 2 kicker comp r 12s i think there 2 ohms i have a black ice amp, if i bridge them will they work at 1 ohm?
if it's a mono amp u don't bridge it (cause it just has 1 channel) when u say 2 ohm do u mean each sub is dual 2ohm if so then each sub would be 1 ohm., u don't want that u want 2 d4 sub each wired to 2 ohm that makes a 1 ohm load... unless u getting subs crazy crazy cheap or free we can help u get much better sub/s like 1 12 as loud or louder than both of those.. which ice amp do you have?
IDK why OP edited/deleted 1/2 of the first post, maybe not like the truth??
That said, THIS is the AMP that was posted
PRECISION POWER BA800.2 Black Ice Series Class A/B Amp
Its not 1 ohm stable.
OP, Instead of posting BS, why not ask the community for a solid recommendation in your price range for what your trying to do???
floridaguy727
floridaguy727
arkansas
poolman966554
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
