wiring 1 voice coil
magnumsrt8215
Can it be done on a dvc safely? I have a big problem I ned a sub that I can't find anymore and I have one that's a dual 4 but I need a single 4. Can I hook up the 1 vc put it in my sealed box with the other 3 putting about 2200 watts btween all of them and be safe? The car is not a daily driver, I don't do compitions and I don't listen to it really loud like that anymore. Can I pull this off and be safe?? Oh almost forgot to mention the subs are eclipse 8122.4. I can't find 1 aywhere and ben looking for 8 months
no you cant it changes specs on the sub such as bl and alot more!
huh?? for a better answer no because it causes cooling issues with the sub.. it will burn up.. youcan do it in a pinch but for a dialy driver no
You can do it. Sealed the T/S shift isn't as big of a deal as it would be ported. The powerhandling will be down, but not cut in half. Probably about 75% of RMS as a rule of thumb will still be safe.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
141
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
195
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
416
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
383
magnumsrt8215
magnumsrt8215
Philadelphia Pa
Haunz
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
