Wiring a second battery, what fuses do I use?
  • 1
Aleks15Civic
I've got two of these:
Amazon.com: Brand New XS Power XP950 950 Watt Power Cell Car Audio Battery Power Stereo System with Terminal Hardware and Installation Instructions: Electronics
I am so confused on the fuses I need to use.
Also I understand I should wire in parallel but do I run the negatives directly to the terminals or through the chassis?
Oooh, and since my amps are going to be close to the battery, it is okay to wire them directly to the negative terminal right?
I will be pushing about 2000RMS if that helps.
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
121
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
189
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
404
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
376
Aleks15Civic
Aleks15Civic
Everett, WA
Aleks15Civic
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
