Wiring Amp with DVC subs
  • Thread starter <JJ>
  • Start date
  • Replies 2
  • Views 2K
  • 2
<JJ>
Guest
I got a 200 W X 2 (@ 4 ohm) amp, and plannig to get a pair of DVC subs, should I get 4 ohm models
or 2 ohm?
How should I wire the amp, with the subs you
recommend me?
check out this kick butt website, tons and tons and tons of answers to all of your questions. DVC's = alot more power to pump the subs! might want to look into 2 SVC subs, what is the total wattage when the amp is bridged? can the amp handle a 1 ohm load? DVC doesnt always mean better, especialy with your amp. Depending on the stability of it. Check out this page... Good luck
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
if you get dual 2ohms VCs just make sure they can handle 200 watts each..but if you get the 4ohm version whatever your amp pushes at 2 ohms is what they need to handle.
Mike
648
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guest
mykeys
