Wiring and install question
you wire the sub in series meaning wire positive coil 1 to negative coil 2 them them take neg. coil 1 to neg on amp and pos. on coil 2 to pos on amp
so if i wired it up the way that link says, would the amp be bridged because its wired to the positive of one channel and the negative of the other channel?
Yes the amp will be in mono/bridged mode..just be sure to set your switch from HPF to LPF and turn bass boost down to zero,and gains down and adjust accordingly
what is hpf and lpf? and it would only be putting out 140 more watts than the subs rms when bridged. why would i have to turn everything down?
High pass filter,and low pass filter...you will be generation more power going into mono/bridged mode...i say turn your gains down due to clipping/and or possibly damaging your subs just by a flip of a switch..deff a precaution measure to take/consider
I couldnt find anywhere specs wise that the amp is 2 ohms mono stable..just 2 ohms x2 in stereo stable, and 4 ohms mono/bridged stable..may need to call the manufacture to get the answer on that to run 2 ohms stable mono/bridged, and also look at your pamphlet/specs booklet..I cant find that..i would say its not by specs ive googled up,so i wouldnt try it,you can damage the amplifier/and or your subs too
I think i pretty much know how to do it now. Looked up a few diagrams and i understand em for the most part. But someone give me a definite answer, u can wire a 2 ohm sub to a 4 ohm load without hurting it right?
HUH?
u have a 2ohm Dual Voice Coil sub. u have two (2) voice coils in your sub that are a 2 ohm resistance EACH! THE SUB IS THE LOAD
You wire both voice coils in series to create a 4ohm load to the bridged amp.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Do you not have a harness that is plug and play with the OEM wiring? Meaning you buy an aftermarket wire harness, splice the small harness with...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
438
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
499
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
554
drewbillingsley
drewbillingsley
lagrange, ga
drewbillingsley
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
