Wiring and Setup Help, Which Wattages to Use
  • 1
schmittmj99
Hello
Equipment:
Alpine CDA-9815 Head Unit (2 Way and 3 Way Crossover capable)
Boston Pro 6.5 Components (Have run passive, willing to go active
20-400 watts, 3 ohm
Boston Pro 10.5LF Subwoofer (I have 2 of these but am fine with using just 1 if need be)
50-1100 watts, 4 ohm
Phoenix Gold XS2500 2 Channel Amplifier
125 WRMS x 2 at 4 ohm Stereo
250 WRMS x 2 at 2 ohm Stereo
500 WRMS x 1 at 4 ohm Bridged
Phoenix Gold XS4600 4 Channel Amplifier
075 WRMS x 4 at 4 ohm Stereo
150 WRMS x 4 at 2 ohm Stereo
300 WRMS x 2 at 4 ohm Bridged
Now, the question. Which way would you recommend wiring the equipment?
#1 , Passive with 2 subs
XS2500 -> 6.5 Components with Crossover at ~190 WRMS 3 ohm Stereo
XS4600 -> 2 x 10.5 Subwoofers at 300 WRMS 4 ohm Bridged
#2 , Passive with 1 sub
XS4600 -> 6.5 Components with Crossover at ~115 WRMS 3 ohm Stereo
XS2500 -> 1 x 10.5 Subwoofer at 500 WRMS 4 ohm Bridged
(Only using 2 channels of the 4 channel amplifier)
#3 , passive with 1 sub
XS4600 -> 6.5 Components with Crossover at ~300+ WRMS 3 ohm Bridged
(Using 4 channels of the 4 channel amplifier)
#4 , active with 1 sub
XS4600 -> 6.5 Components without Crossover at ~75-115 WRMS 3-4 ohm Stereo
(Boston only lists the impedance of 3 ohm with the Crossover and not the individual woofers and tweeters)
#5 , active with 1 sub
XS4600 -> 6.5 Tweeters without Crossover at ~75-115 WRMS 3-4 ohm Stereo
XS4600 -> 1 x 10.5 Subwoofer at 300 WRMS 4 ohm Bridged
XS2500 -> 6.5 Woofer without Crossover at ~125-190 WRMS 3-4 ohm Stereo
Thank you for any assistance and insight.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
248
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
650
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
673
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
671
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
576
schmittmj99
schmittmj99
Wisconsin
schmittmj99
Decebal
    Jun 10, 2024
